WIP Racing Sim with G25.
- Still to do: Finishing/Painting/Decor, 2.1 Sound System (sound from monitors so bad) ; Real Dash/HUD; Cable management ; 2 more monitors; etc. etc.
Many thanks to Ethermaster for finding me a reasonably priced used GPU (£50) and new Corsair Case for my old OEM PHENOM.
Existing old PC: AMD Phenom 9550, quad core, 4gb ram
Monitor: OC Iiyama Prolite E2483HS-B1 24" Widescreen LED Monitor x1 (need 2x more!)
GPU: Used, MSI R5870.
..playing Grid 2 Destruction Derby a lot of fun!
Finishing will probably take longer than the build but am up and running !
The Timber parts (£49 Total)
Cutting the side panels:
G25 Gearbox Housing:
Yes you need a seat.. (couldn't afford a racing one at this time)
Inverted Pedals as it was meant to be...
Not without problems..argument with one of my workbenches
Playable and needs finishing !
