- 26 Jul 2014
Since introduction threads are a bit boring I skipped that and thought a project thread may be a better starting point.
I am currently running the following spec:
Gigabyte GA78LMT
FX-6350
MSI OC BE HD7970 (Was previously an Asus DirectCU2 GTX660, then PowerColor R9 280x, the change to the HD7970 will be covered later)
2x Plextor M5s 128GB SSD
1x Seagate 500GB HDD
Corsair CS650M PSU
For cooling:
XSPC 750 Pump/Res
XSPC EX120 Radiator
XSPC Raystorm CPU block
Case:
Zalman Z3 Plus
The case is quite decent for £35 or so, however a single rad doesn't fit inside the case, so it's on stand offs at the back which looks messy, I also looked to upgrade my graphics card and was offered an R9 280x, at this point (finally running BF4 on Ultra decently), I decided to watercool the GPU.
The first stumbling block was that the R9 280x I had wasn't a reference card, and I was struggling to find one that was, so I decided to go for the MSI OC Boost Edition 7970 which is giving me pretty much the same performance, and is a reference card.
To go with this, I got an EK-FC7970 Waterblock and back plate, the next problem was that I would never be able to cool the card and CPU adequately on a single 120mm rad, but I couldn't fit more in my current case, so a new case was next.
Then the maths didn't work out with the XSPC 750 pump, so I now have an XSPC D5 Pump/Dual Bay Res combo on it's way, which should give me enough pressure to keep a decent flow through the loops.
So my proposed spec will be as follows:
Case:
Fractal Design Arc XL
Hardware:
Gigabyte GA78LMT
AMD FX-6350
8GB RAM
MSI OC BE HD7970
Plextor m5s 128GB x2
Seagate 500GB x1
Cooling:
XSPC Raystorm CPU Block
EK-FC7970 Waterblock & Backplate
IC-Diamond 24
XSPC EX240 Slim Radiator
XSPC EX360 Slim Radiator
Corsair SP120 x6 (5 on rads, 1 on intake at bottom of the case)
Corsair AF120 x1 (Rear Exhaust)
First thing is, wow at the case.
I mentioned to a friend it is like the Volvo of computer cases, big, strong, well made, yet subtle but surprisingly nice looking for how simple it is.
Currently, I am as far as fitting the waterblock and backplate to the HD7970, the next step tomorrow will be to drain the old loop, clean out the CPU waterblock, refit with new paste, then fit the card into the new case, then build up the loop, leak test, then power it up and do temperature checks.
So hopefully, it will all be fun and games, photos to follow
Gigabyte GA78LMT
FX-6350
Corsair CS650M PSU
For cooling:
XSPC 750 Pump/Res
XSPC EX120 Radiator
Case:
Zalman Z3 Plus
Case:
Hardware:
Gigabyte GA78LMT
AMD FX-6350
8GB RAM
MSI OC BE HD7970
Seagate 500GB x1
Cooling:
IC-Diamond 24
