With the inspiration of similar recent project I've decided to turn this old case I had lying around...
Into an overclocked Red monster of doom. Naturally on a budget although the budget's a bit higher than other recent examples of about £400 it's still fun and hopefully you guys will enjoy it too
Mobo and PSU fitted, Mobo is the Abit AN8 Fatality although won't be using the Nguru module as it's the wrong colour and not practical to respray.
CPU, 3500+ Venice cored with a Arctic Cooling Freezer 64 Pro CPU Cooler. Since buying it I understand this cooler might struggle beyond 2.5ghz - we'll see. As you can see it's got help from 2 80mm fans plus the 2 fans on the mobo ( covered by the black shroud ). I'll also be adding a blowhole and 80mm fan just as soon as I can work out where.
.Mobo and PSU fitted, Mobo is the Abit AN8 Fatality although won't be using the Nguru module as it's the wrong colour and not practical to respray.
Cut a few windows into the side panel and it'll look perfect.
Good luck with it. I have high expectations for this project.
