Project Ruby Referb
10 Dec 2007
South Yorkshire
I had planned on starting a new project this year but after giving it much thought plans changed and i decided to give the Obsideon a make over.
Got a few knocks and scratches on the outside they will have to stay for now just going to concentrate on the inside for now.Water is starting to look a little green and the dust is building up :(
When first built it only had cpu and gpu water cooled even though i always wanted to get everything done, money was an issue at the time .
So lets start by giving a few shots of the original build from 2 years ago,
excuse the poor picture quality my camera isnt the greatest..
So whats changing your probably thiking ?
#2 Firstly im upgrading(upgraded) too 12 gb of Corsair vengence
#2 changing the tubing to clear Masterclear
#3 Fluid to Mayhems X1 UV Red
did have clear fluid in the red tubing but didnt like the effect under UV that much
#4 XSPC 240 in the bottom (with possibly a 120 on rear or middle shelf)
#5 EK water blocks for mobo and mosets to match the GPU
#6 the rest is mostly cosmetic stuff EK back plater for GPU , Bitspower fittings,led strip lights, shiny led fans for bottom rad and rear case.
Well all didnt go quit to plan over the weekend having to spend two days waiting for a faulty replacement part,
but all is built and running leak free .
on full load with Prime 95 the hottest core is 51c
gpu is maxing out at 37c
and the NB/SB 37c which is nearly 20 degrees cooler than is was.
and gone is the noisey fan over the mosfets .
Thanks.. just waiting for a couple of screws and bits to finish off the cosmetics
then its complete untill my new build anyway :D
