Ok well for starters this is a long mod lots of things will change to this case but expect the full project log to be finished in 6months to a year.
first I had the horrible job of cable braiding. I decided on doing each cable separately. Sadly no pictures of the braiding but then again everyone has seen that (but will get one when I can do a decent pic of black cables).
well first I have all the parts needed to build my loop.
here are some of the items in the mod
Lian Li V2110B
Ek Supreme HF (2010 v1 model)
Ek X-TOP/D5 combo
Thermochill PA120.4
Mcubed T-Balancer BigNG
Bay res
and blacksparkle compression fittings
MB:ASUS A8N SLI Premium
CPU: AMD FX 60
RAM: bla...
GC: 7600gt
And here is the Lian Li Beast this thing is MASSIVE but then it's gonna need to be to fit this rad.
Ahh the BigNG the perfect tool for stress free silent cooling.
And here is that thermochill rad sadly disaster has struck and I managed to get the only one that has a leak (be it a small one) in the core of the rad(would have to be mine that was a one off).
Once the new one has been received and I get my refund from the competitor ill be re building the system. Reason being is this time I plan to install a few rotary joints in (to make my life easier) along with a draining tap using a ball valve.
Gonna have to get the dremel out soon as that metal is getting in the way.
However the motherboard sadly died a few weeks ago and so I've upgraded
. Luckily I have enough parts now to build the system (no pic's yet for new parts need to get some batteries for the camera).
Rads now flushed and has gasket and fans installed.
New Parts
i5 760
MSI GD-85
Dominator GT 4gig
Nvidia 460gt (with nice new full cover EK waterblock)
so only a slight upgrade
and found some Bitspower bits and those rotary fittings but sadly no drain value yet annoyingly
However when swapping the systems over I noticed that this coolant that was supposed to be a one stop solution, has algae deposits in now (has clung to a part of the res and was discolouring the tubing which was a pain). So trying out some PHN PT_Nuke stuff hoping it will kill it all then gonna replace the coolant with something different anyone got any suggestions ?
oh and btw this was from an old post on a competitor so a few months have past since it was started but been restarted due to being able to get the ball rolling again. Pic's of the new system installed to come soon along with some old mb tray work i did
(even if it is a little sloppy
Lian Li V2110B
Ek X-TOP/D5 combo
Thermochill PA120.4
Bay res
CPU: AMD FX 60
RAM: bla...
GC: 7600gt
New Parts
i5 760
MSI GD-85
Dominator GT 4gig
