Hi everyone!
I'm looking to get back into SIM racing after a long 5 year absence. I'm starting from scratch as all previous hardware failed to accompany me over the journey!
I've come to accept that it probably isn't going to happen instantly, more likely to take until the end of 2014 to have my rig complete. Buy one can dream...
I'll be on a budget but can't really say what it is as I'll just be buying components whenever I have some spare cash. Im hoping to have change from £1k though when all said & done.
So I've been doing some research over the last couple of days and after originally thinking Intel is the No.1 choice (which it probably is?) I think I can probably get the bang that I need with an AMD processor, for a lot less buck!
Considering the only gaming I'll be doing is SIM racing (to include Assetto Corsa & I racing amongst others) I've come across the following CPU & GPU and was hoping if anyone could tell me if this is a good starting point and would handle the game requirements adequately....
AMD FX6300
ASUS AMD Radeon HD7850.
As I say, this is what I've come up with after a couple of days googling. I'm a total novice with computer components and what they all mean so I won't be offended if you pull my selection to pieces!
I look forward to any advice or further recommendations, both computer components and/or SIM racing!
Regards,
Simon.
AMD FX6300
Regards,
Simon.
