Permabanned
- 15 Dec 2008
This is where I'm at so far, the plan was to stuff a 5Ghz 3770k, a Sapphire 290 Tri-X in a tiny Lian Li Q25B and then water cool it all which as far as I know has never been done in this case before.
Anyway...
Some pictures with the rads fitted and a GTX 460 with the heat sink removed so I can gauge the space I have left for fans and from looking at I should be able to easily get a set of 12mm slip stream fans on that rad and have room to spare!
Still got to cut the bottom out when my Dremel gets here, was dispatched today so hopefully will be here tomorrow.
And I need to figure out what pump I'm going to use, I don't think my current Laing DDC will fit with a pump top so I might end up having to mount it on a fan bracket or get a smaller pump or one of these pumps that are integrated into the CPU block.
Then there's HDD mounting to sort out, no idea how that's going to work,...yet...
Anyway...
