This is a watercooling project on my existing build, also my very first attempt at watercooling! Mostly external too
The Three main components that will be used are the following:
WC wise the following spec has been settled on, well just about anyway.
XSPC Raystorm CPU Block
2 x EK-FC6870 plexi blocks (my 6950's are based on the 6870 PCB)
D5 Vario W/ Alphacool HF top
7/16 black speckle/black nickel compression fittings
7/16 White tubing (undecided between masterkleer and XSPC?)
Coolant will just be some DI with biocide/kill coil/corrosion inhibiter
How things look just now:
The absolutely huge radiator (essentially 3 x 360 rads to put it into perspective:
It may be slow progress to begin with, as I can't really do much of anything until I get the 6870 blocks in, which OCUK are very kindly ordering in for me (thanks Rjkoneil you're a star!) But at best the blocks will be with me next week, so fingers crossed for a build next weekend!
- Sig rig, including the 500R
- Zalman Reserator v1+, pump removed to be used as a huge 2.5L res, should also take care of around 160w heat
- Phobya Xtreme Nova 1080 radiator with 4 x 180mm Phobya G-silent 700rpm white fans.
