Project TJ07, Long, Slow, Watercooled Build
So here's my take on the Silverstone TJ07, always fancied one of these cases and my chance has came!
This wont be a quick build, I have another project on the go which will take priority, this will be done in the free time I get and when things come up.
Now I've seen a fair few builds in this case and not all of them I like, one of my favourites as Andrew Moores Carbon Green TJ07, like the green coolant and the open front.
My current pc has been green through all its stages so I sort of want to change a little but I do like the uniqueness of the green scheme so I may stick with it!
Im not one for copying others builds, I like to come up with my own ideas and ways to do things, and do things people think cant be done or wont work!
Anyway, my initial ideas for this are as follows,
-480 & 240 rads plus a D5 pump in the bottom compartment.
-CPU and GPU piped up parallel as RJK first done and my current build is.
-Open drive bays with an acrylic window and the res sitting in there too, got a 250mm tube res so with a single Blu ray drive at the top this will go through into the bottom compartment, no tubing in sight.
-Replace the top mesh with a tinted windoow.
-Will probably replace the back panel with a Pulse Modding one without the fans as well, that'll leave the top sealed so may have to put a fan in there.
Few starter pics
Need a 480 rad stand but only have this for now...
Few starter pics
