Just taken delivery of my Antec 300 along with some other bits and so starts the project.
To Do List:
1. Move the on/off and reset switch to the top of the case - want this done as my case is below me and so top mounted switches would be an advantage.
2. Window into side pannel - just showing motherboard.
3. Spray paint inside of case black.
4. Replace case feet - Original feet are not bad but have decided to go for aluminium with rubber insert feet.
The switches ive decided to use are black Lamptron Delrin Vandal Resistant switches.
These have a circular coloured glow, decided to go for red on/off and orange reset switch. Pics below.
The switches holes will be the first job to do and will be drilled / mounted as shown by the black circles in the photo below.
The switches will prevent the top drive bay being used for dvd drives although this wont be a problem as a fan controller will be inserted in the top drive bay.
The original front switches will be removed and the hole filled.
Update will follow once the switch holes are drilled.
To Do List:
not the best thing to do but seemed right at the time lol. Any one know why this reaction happened? the primer was plasti kote metal primer and the top coat was plasti kote satin black.
