Project Water 2.0 - Caselabs SM8 Upgrade
  • Thread starter Thread starter RSR
  • Start date Start date
RSR
RSR
17 Aug 2006
Welcome to my 2.0 Build Log.
After starting my original build log last year, I’ve not been happy with the thermals and build-up of heat within the case. So, I have now decided to pull the plug on setting the system up for not only my current X99 setup but to upgrade to either X299 or X399 platforms.
Here is the link to Project Water 1.0 > Here
So the new parts for this build are:
Case:
Caselabs SM8 - Black
Flex Bay 360 Mount with Vented Bay Covers
Drop-In Top Rad Mount 120.4
XL Window
USB 3.0 I/O Pannel
Singularity Computers:
Singularity Computers Reservoir Mount Ethereal Single V3 X2
Singularity Computers Protium Reservoir - Medium - Frosted Acrylic
Singularity Computers Protium D5 Pump Top - Frosted Acrylic
Singularity Computers Protium D5 Cover - Black / Silver Rings
Aqua Computer Components:
Aqua Computer Aquaero 6 XT - Blue
Aqua Computer Front Bezel For Aquero 5 and 6 XT - Black
Aqua Computer Passive Cooler for Aquaero 6 - Black
Aqua-Computer D5 pump with USB and Aquabus interface
Aqua Computer High-Flow Flow Sensor
Aqua Computer SPLITTY9 splitter x2
Aqua Computer farbwerk USB - Pending
Radiators & Fans
Black Ice Nemesis GTR 360 Radiator - Black X 2
EK Water Blocks EK-Vardar F3-120 X 14
WC Fittings:
Bitspower G1/4 Black Sparkle Rotary 90 Degree ID 1/4 Adapter x 9
Bitspower G1/4 Enhance Multi-Link For OD 16MM - Black Sparkle x 12
Bitspower G1/4 Black Sparkle Rotary IG1/4 Extender
Bitspower G1/4" Black Sparkle TII- Rotary Adapter
Bitspower G1/4" Black Sparkle IG1/4" Extender X6
Bitspower G1/4" Black Sparkle Anti-Cyclone Adapter
Bitspower G1/4" Black Sparkle IG1/4" Extender - 25mm x4
Bitspower Premium Sealing Plug 14 - Black Sparkle X4
Bitspower Stopcock 1/4 Inch, Silver Handle - Black Sparkle
Bitspower G 1/4" Black Sparkle Temperature Sensor Stop Fitting
Bitspower PETG Link Tube OD16MM x 4
Extra Parts / Upgrades:
Seasonic Prime Platinum 1200W 80 Plus Platinum Modular Power Supply
G.SKILL F4-3600C16Q-32GTZR 32 GB Trident Z RGB Series
DarkSide 3mm DarkSide Connect Modular LED - White X3
DarkSide CONNECT 3x Y Cable - 4-Pin - 12"
Thermal Grizzly Kryonaut High Performance Thermal Past
MDPC-X Sleeving - Black & White
Peripheral Upgrade
Logitech C922
Corsair K95 Platinum RGB Rapid Fire Cherry MX Speed
Corsair M65 PRO Multi-Colour RGB
Corsair VOID RGB Wireless USB Dolby 7.1 Multi-Colour RGB
Parts Due Soon / Waiting
EVGA 1080 Ti FTW3 + EKWB or AMD RX Vega - Waiting
G.SKILL F4-3600C16Q-32GTZR 32 GB Trident Z RGB - OCD Kicking in again and may order another set so it doesn't look empty.
MDPC-X Full Custom Cabling - Ordered waiting to arrive.
DarkSide Connect Rigid LED White 12" x2 - Ordered waiting to arrive.
Black - M4 x 30mm bolts - Ordered waiting to arrive.
Edit 28/06/17 - Content Update.
Singularity Computers Pump and Res Combo, Ive wanted one of these for a while now and seems to be the best on the market at the moment.
Aqua Computer Parts, these have been highly recommended by a good friend.
This was my first attempt at cable sleeving and I am pretty pleased with the outcome on these cables. However, it took a lot more attempts than what I thought it would.
Fittings..... Ooooh look at the shiny shiny....
These rads seems to be very highly rated from my research. :D
Darkside Lighting:
The odd bits and bobs..
I've been looking at the paint options for the Caselabs SM8 as its been ordered in Black. However, I have been thinking about having the whole case painted in ether a pearl white or black.
However, I need to complete all the test fittings once the case arrives.
So construction time........ :cool:
Yes, I do need to hoover the floor as its covered in crap. :p:eek:
Quiet a few hours later and one finished case.
Time to start the test fitting and alignment.
:mad:
So first technical problem, the bolts which came with the Hardware Labs radiators are miles to long, so rather than cutting them down I have ordered some which should arrive by the weekend. As a temporary measure I have used some M4 x 30mm bolts which are OK for test fitting but they are too short.
I've realised due to the configuration of the flow meter, I am going to require a few more fittings so these should arrive on Friday as I've had to order them for a store in the EU as not many people carry a full range of the Bitspower Black Sparkle fittings.
I'm very impressed with the case, as it seems to cover off all of my requirements. Once the test fitting has been completed, then I need to plan the mid plate / PSU cover. So i'll get that all measured up and sent off to be cut out. I'm not sure on the colour or material choice of that yet.
What I do need to get is side by side picture next to my Phanteks Evolv TG as a size comparison.
Very smart case looks easy to work in.... I'm sure this will be a great build, Great choice of Corsair products :cool:
Few updates from the weekends progress:
New (SM8) Vs Old Case (Evolv - TG - Top Lid Removed)
Res and Pump Fitting
Motherboard trays making working on the main setup so much easier.
A few hours later, a loop apears. :p:D
Testing done & Time for the pastel white
I'm not overly happy with the bottom bit of tubing up to the GPU, so that will need to be re-worked. However, I have a mid plate to install next as well as get all the custom cables ordered. I'm also thinking about changing the pastel white, as it doesn't work with the Darkside LEDs on the reservoir so I need to have a look at the range of Mayhems Dyes.
Jobs List:
> Mid Plate
> Custom Cables
> Polish Tubes. :o
> Re-Work bottom GPU Tube
> Change Silver Fan bolts to Black
> Get a better Camera :p
I'm hugely impressed with the temperature results going from the old setup to the new setup, as the coolant temperature looks to have dropped 10/15c. Also load temperatures have also dropped by the same amounts under load.
loving the tube runs, everything fell into perfect alignment. Although for me personally the GPU portion looks a tad odd in that you've used a pair of extenders to raise above the sealing plugs, but you wouldn't have needed the extenders if you switched the inlet and outlet around; feels a bit off that you have this cross-over going on breaking the otherwise diagonal flow of the tubes.
Looking good dude... love it... :)
Stelly
Thank you.
Thank you.
Unfortunately I've needed to used the extenders as the 90 with the 16mm fittings rub on the GPU back plate, the GPU part of the loop is still up in the air at the moment till I can get the mid plate in and at which point I can finalise the design. However, it may all change again if the GPU is changed for a 1080Ti or Vega. I do think the Bitspower fittings do finish it off nicely even though they are far from cheap.
I'll going to redo a few bits of tubing as they are not perfectly square so its driving my OCD nuts at the moment. :(:p
Also I may change the pastel white back to clear or UV I am still not 100%
Ah, gotcha. I'm working with 12mm OD fittings so the backplate clearance never occurred to me. Still looking sweet as a whole though.
Kick your OCD in the nuts - it looks great.
I'm a big fan of stark, minimal two tone builds - and yours looks superb.
When you're that close to a build you notice every minor detail and I can appreciate how these thing can itch the brain - but seriously kudos - you seem to have little/nothing to worry about.
Thanks Chaps. :D
A quick update, I've just confirmed custom cable design today and it's going to be a week or two before they arrive. These are all going to be custom build AWG 16 wire with MDPC-X Sleeving, I've taken a risk with the colour scheme on them but I think its going to look epic! :D
My Darkside LED Strips have been sent today, so ill update the thread if they arrive by the weekend.
I'm also in two mind about the mid plate now, as my custom cables should layer all quiet nicely but I'll see once they arrive.
The last thing I've been thinking about changing the fans out for Corsair ML's but that's under review at the moment. :p:D
Thanks chaps.
I should have another update due next week or the week after depending on when the parts arrive.
Few updates, as I am still waiting on the custom cables to arrive.
Darkside - White LED Strips Installed.
Changed Silver Bolts to Black Bolts
Changes Fans to the ML120 - Whites
Updated Pictures:
Items still due:
Full Custom MDPC-X Cable Set - Quad Colour Combo
3 X Corsair ML120 Pro - White
3 X Corsair ML120 Pro - Black
Items Under Reviews:
EVGA 1080 Ti FTW3
AMD RX VEGA
