Project: Watery rev. 2
AJ_
AJ_
30 Apr 2007
LINK to revision one
Watery rev. 2
It’s been a good old while since watery has had an update, let alone any progress, and to be honest, I got utterly stuck on how to mount the reservoir to the actual case body, while still being able to remove the case panels to get to the hardware, so it was time to start over anew.
Revision two is going to be the same basic idea, but on a larger scale so I can get in a full ATX motherboard, and dual water loops as I want to go full out this time. There will still be truck loads of milled and laser cut acrylic, but quite a lot more chrome this time, with the back panel, motherboard tray, radiator ‘pods’ and floor all being made from aluminium. This will reduce costs, and hopefully my blood pressure as putting a decent thread in acrylic was doing my head in.
So, going in will be:
ATX Mobo and the usual hardware
GPU or so.
2x HDD/SDD's
External DVD Drive
Dual water loops
2x120.2 Radiators
Dual DDC's
Dual custom res's
Drain ports
Integrated lighting system (more in this in due course)
This time, I also want to set this project out in stages, so I don’t get confuddled, so here is the basic plan...:
Stage 1 – Manufacture of radiator mounts,
Stage 2 – Manufacture of base, motherboard tray and back panel, feet and support columns.
Stage 3 – Chrome every piece of metal I can find.
Stage 4 – Build the lighting system.
Stage 5 – Hardware modification & cable mods.
Stage 6 – Reveal the reservoir.
Stage 7 – Profit....
Before I give you the first glimpses, I have to give a shout out to a few people on Bit-tech and on Xtreme Systems who have given me a hand with designs and suggest some neat ideas:
Bill Owen, of MNPCtech fame
Cyberdruid
Charles_h
Cheapskate
Soooooo, without further ado, I give you...
UPDATE 1
A quick start, just to I can get my hand back in...
The radiators are going to be mounted length ways on either side of the base of the case sucking air in, and blowing out towards the PSU. The plan is to have all of the cables from the fans etc. hidden within the radiator mounts so just the water tubes stick out, using a set of Bitspower universal fillports. So, let’s start on the ends :)
nom nom nom
BTW, no much in this first update, just to show I'm actually doing stuff for once :p
Second side as well today. This means I can start working on the base panel and on the mid tray over the next few days.
(Althought its not obvious, both bolts are fully countersunk, they just aren't fully tightened.)
picture.php
The plates that mount onto these two bits I've just made are going to be laser cut aluminium as they need to be reeeeealy accurate. And although none of this will probably make sense now, once I've finished the radiator mounts, all should become clear...
I few pics showing what I've already hidden away from Watery rev 1. for this project... they have been seen before, but no-one has ever complained about shiney things have they?
A HWLabs Black Ice GT-Stealth 240 radiator in Chrome, okay, well a pair...
:D
While coming up with the cad files for the water jet people, I decided for the sake of explanation, I would do a CAD render of the bottom half of the case...
As you can see, there are two 'pods' on either side of the base, each containing a 120.2 chrome HWLabs radiator, and a pair of AC Ryan Kameleon fans. Also, so that this is as tidy as possible, Im going to put the SSD's (or at least thats the plan) in the side bits as well behind the radiators. Also, there are like 12 holes in the side of each thing to take a 3mm LED and holder, to give some 'glow' to the base of the case.
The mid layer (not drawn yet) will house ALL the cabling, so all that is visible will be the 24, PCI-E and one or two Molex cables going into the middle section, or atleast thats the plannn...
So, here is how it should look after a little water jet luuuuuuve.
