This project is going to be based around acrylic, and lots of it.
The basic plan is too have the PC parts (inc. water-cooling stuff) in a solid case measuring 320 x 320 x 400 (mm) and then around that box I intend to have a resevior covering both side panels and the front panel. This will be made using 10mm acrylic cut to 45* then cemented together.. The Motherboard will be mounted flat on the top (like a MM Horizon or something). More details >here<
Anyway, I decided to make a start today.. The Radiator will be mounted on the bottom so its gonna need some air flow, so I set about making some legs today. The front of the case will have a 'skirt' so these needed to be quite long. They are made from offcuts of 1" Aluminium...
I started with a pilot hole...
Then drilled out with a 4.3mm hole so it can be tapped to M5. I'm using paraffin as my cutting compound because I was told to..
Then tapped to an M5 thread
(Also, I'm gonna need a decent name...)
