- 11 Jul 2011
Hi all,
I wanted to start a project thread as I’m about to embark on my first ever custom PC build. I’ve been into ‘tech’ in general for many years (been a member here for 12+) but I’ve never actually built a system. Hell, I’m still fairly new to Windows having been an Apple fan for many years.
Anyway, here’s my list of parts. Some of them have arrived recently, some are due tomorrow and the final pieces to the puzzle arrive on Monday. Very excited!
Monitor 1: Samsung Odyssey G9 49” 240Hz paired with an Ergotron HX arm with the HD mount
Monitor 2: HP 32s 32” mounted directly above the G49
Keyboard: Logitech MX Keys
Mouse: Logitech MX Master 3S (although very tempted by one of the nicer Corsair ones instead)
Desk: Flexispot H7 dual motor sit/stand paired with a 246cm IKEA worktop
Chair: Andaseat Kaiser 3
Mic: Elgato Wave 3 on the Elgato low profile arm
Now onto the standard bits of the PC build:
Case: NZXT H9 Elite in white
CPU: AMD Ryzen 7 7800x3d
Motherboard: NZXT N7 B650E in white
GPU: MSI RTX 4070 Gaming X Trio 12GB
RAM: Corsair Dominator Platinum 32GB 5600MHz CL36 in white
Fans: 9x Lian Li Uni Fan SL-Infinity 120mm in white
PSU: Corsair RM850e (2023)
SSD: Samsung 980 Pro 2TB
Monitoring/Sensor Panel: Elecrow 7” 1024x600 (I’ll create a custom display using AIDA64)
And last but not least, the custom loop components:
Pump/Reservoir: Corsair Hydro X XD5 D5 PWM in white
CPU Cooler: Corsair Hydro X XC7 Pro in white
SSD Cooler (lol): Corsair Hydro X XM2 M.2 block in white
Radiator: Hardware Labs Black Ice Nemesis GTX 360mm in satin white
Monitoring: Barrow Digital OLED display with temp and flow sensor in white
Fittings: Barrow 14mm fittings in various sizes, all white
Tubing: Alphacool 14mm PETG hard tubing - 6.4m
Fluid: Corsair Hydro X purple
Total cost: £5,400
I really enjoy the research element of stuff like this. I genuinely knew nothing about building a custom PC 4 weeks ago - and I still don’t!
It would be a fair argument to say I’ve bitten off more than I can chew by going straight in with not only my first custom build, but also my first custom loop. I’d say the learning curve of water cooling was steeper than building the machine itself - probably because I at least understood the basics of PCs.
I’m fully expecting to end up rowing down **** creek without a paddle on multiple occasions, but I have no doubt I’ll get there eventually.
I’ll update this thread with pictures of all the parts before the build begins and keep it updated with progress as it goes!
I’m also doing this alongside creating a home office in a spare room so it’s definitely going to be a hectic few weeks juggling work, family, the kids and this - but I can’t wait!
Comments/criticisms/tips are all most welcome! Thanks for reading all - I have no doubt I’ll be learning on this place throughout the build!
Total cost: £5,400
