Finally got some time to start work on the Lian Li A71B I bought a few months ago.
Think I have everything I need, although I'm bound to end up adding more stuff.
Its going to be quite a short blunt worklog as I always manage to forgot to take in progress pictures as I go, far more fun just building
Lian Li A71B
-Anodised black internally
-Fittings for PA120.3 in the top along with Brushed Aluminium rad grill
-Drive bay moved back to allow a pa120.2 in the front
-2 Fillports fitted in the top
-Smoked Side window
Dual loops. 1 fillport each, one 100ml EK Cylinder Res each. Black Feser1.
1)
-PA120.3
-DDC Ultra with Alphacool top
-Dtek Fuzion
-Swiftech MCW30
2)
-PA120.3
-Swiftech Stealth
Fitting the PA120.2 in the front was a fiddly job. Couldn't get the screw holes lined up at first. Eventually realised I was just being dopey. The fan+rad combination is held onto the front of the case by 4 bolts. Sadly none of the original holes from the front for the 2 fans lined up, so 4 new holes were drilled in.
The Harddrive bay has had the top bay cut out, to allow for the tubing to come through. The bay as a whole has been moved back about 2" to allow for the PA Rad to fit in.
My Cat approves of the Pump Placement. My Enermax Liberty Powersupply looks very small in there!
Fitting the PA120.3 in the top was a far easier affair than mounting the 120.2 in the front. Well, when it was once I had found the screws which I was panicking I didn't have. Turned out it was just in a different place to expected after moving home from uni earlier in the week!
Whilst chatting to W3bbo on msn he persuaded me to fit the Chipset block I had. The heatpipe solution came off nice and easily contrary to what I was expecting.
The main problem with removing the heatpipe solution is that I had to do something about the mosfets. Luckily I had some little memsink blocks that should do the trick lovely, along with some thermal tape that will hopefully hold them.
Obligatory Macro close up of the mosfets. The blocks along the top seem to be on solid, however the ones along the back that were covered by the heatpipe didn't seem as solid, when pressing down they tended to shift so I have got a clamp on them which will hopefully allow the tape to do its trick
More to come later.
Lian Li A71B
-Smoked Side window
1)
-PA120.3
-Dtek Fuzion
-Swiftech MCW30
2)
-PA120.3
-Swiftech Stealth
More to come later.
