Permabanned
- 9 Jun 2009
- London, McLaren or Radical
Well... after seeing the start of my WC build... the wifey has decided that she would like her own WC build. I over-ordered fittings and tubing for my build, so will have plenty left over for hers.
It's going to start with the main components that she already had, which used to be in our HTPC - but it's going to progress to 6800k & GTX 1060.
The main components will be:
Intel 3570k
Gigabyte Z77 motherboard
32GB (4x8GB) Kingston Hyper X Savage DDR3
ON-board GPU (for now)
Hardware Labs Black Ice Nemesis GTX 280
Corsair ML140 White LED
EK D5 XRES 140
EK Blue Coolant
EK Blue compression fittings
Phanteks Enthoo Evolv ATX Silver Tempered glass
EK Evo Supremacy Nickel
I bought a CPU block that will be usable with X99 too... for her upgrade further down the line... although she doesn't game, so the GTX1060 will be overkill.
Looking forward to another hard tubing build and will get piccies up of what should be a nice looking system.
Intel 3570k
EK D5 XRES 140
EK Blue Coolant
