Projector fan faulty?
18 Oct 2002
Stoke-on-Trent
Purchased a Benq w1210st projector last month for gaming and love the picture quality etc.
I've now noticed that after the projector has been on for about 20mins one of the fans is making a high pitched whistle.
If I blow on the fan it stops for a couple of mins and then starts again.
It also stops for a while if I move or tap the projector
Does this sound like a faulty fan? If so it's going to have to go back to Benq for repair and I'll be without it for a couple of weeks
I'm surprised blowing on the fan stops it, but yes, from your description it sounds like a faulty fan.
Did you buy it new or used? If new then it should go back to the retailer. Something as new as a month old ideally should be replaced over the counter.
Fans aren't too difficult to replace provided that there's stock of an equivalent part available.
It is a new one but I think the policy is after 30 days then it's a warranty repair. I'll see how it goes over the Xmas period, hopefully it may settle down. If not I'll contact the company I purchased it off to see what they say.
Waiting is a bad choice.
If the fan stops then the projector isn't being cooled because it's not getting the air flowing through it to dissipate the heat from the lamp. Running it like that puts more strain on the other fan and risks the lamp overheating. Delaying the repair means more damage and more expense, some of it your fault and your cost to repair.
I know it's inconvenient timing, but honestly running this risk just isn't worth it.
Also, don't blow on it. Of course the sound will stop, when you blow it you are blowing against it expelling air so slowing it down.
I'll call up in the new year and get it repaired. I've checked and the fan is working and blowing the hot air out, it just makes a funny noise after about 20 mins although I used it for over 30 mins last night and it didn't make a sound!
