Projector Lift recommendations
28 Apr 2010
I'm looking to install a projector lift in my lounge. The projector I have is an Optoma UHD40. The house is a new build, with standard width between joists in the ceiling, and the ceiling is covered by plasterboard.
There are no obstacles between the screen and the projector, and the screen is a 120" EliteScreen electric screen that also drops down.
What would you recommend? Prices range from £200 to £2500 easily so it's confusing to know what you're getting for your money.
I've used some sapphire motorised screens in the past so if I needed a projector lift, I would have confidence in something like the Sapphire SAPPL04
