Projector questions, help with calculations
18 Oct 2002
At home
Ok, deciding on getting a projector to use alongside my current 42'' plasma, rather than replacing my plasma with say a 65''.
Decided on the BenQ W1070+ ( As I need WIFI, hard to get HDMI to projector ! )
Anyways according to their website I managed this:
Which shows for a screen that is 82'' in size, which i think seems more than enough at about 3m distance I need to pretty much put the projector above my coffee table and will be about 70cm down from the ceiling ! seems crazy !
I have mis calculated somewhere ? As if it is that much I may just get the W1080 and just put it on my coffee table when i want to use it.
Yeah your description and screenshot don't match in terms of the distances from wall to projector location, and ceiling to projector distance.
I will try find the website I used when I was calculating mine
EDIT: Distance is the main factor. Ceiling/Coffee table height is really only a factor if your projector doesn't have feet, or if the ceiling mount is static.
http://www.projectorcentral.com/BenQ-W1070+-projection-calculator.htm
Seems to state a screen size of 104" roughly
