Hi all, I am not sure what section this belongs in, so apoligies if this is not it.
I am having problems with a projector (Epson EMP-83):
1. If the output resolution from the source (PC in this case) is anything other than 1024x768 (lower or higher) then the projector displays an 'out of signal range' message.
2. When it does show an output (on dual display clone mode) it only shows a portion of the screen... about the top third. It is also very distorted (squashed).
3. Related to numbers 1+2, in the info section on the projector menu, no matter what the computer reports the output resolution to be, the projector reports its current display resolution as 720x486
The main source computer in question is a dell optiplex 780 with intel series 4 graphics chipset and latest drivers installed, running windows 7 pro. The same thing happens from dell latitude d620 / d630 laptops, also using intel onboard graphics but running a mixture of windows 7 pro and XP pro.
I am sure the projector is OK because if I connect one of my personal laptops (packard bell butterfly touch, also running intel graphics (x4500) and windows 7 HP) to the projector then it works and displays perfectly and all of the above issues disappear.
Any help would be greatly appreciated
Thanks in advance.
Thanks in advance.
