Projector Screen Adjustment
6 Oct 2009
Black Country
Hi,
I've got a cheapo ebay motorised projection screen from about 3 years ago that doesn't roll the screen up anymore. Over time the bit left out is getting longer and longer, and is now about 40cm showing when it stops rolling up. Also when rolling out, it now goes past the bottom stop and winds it self back up, a similar amount at a guess.
So it needs adjusting, but I can't find any adjustment screws in the projector itself, inside by the motor or on the outside.
The controller box has 'electronic limiter' on the back and you can feel a relay move inside when it gets to the point it stops.
So before I ditch it for a better one, has anyone come across a way to adjust this type of screen?
Thanks
Tony
Just to give some closure to this.
I finally got it down, and took the ends off, the one end was just a bearing, the other was on the motor with a keyed shaft. (if that makes sense).
Rerolled the screen up, and repositioned, and jobs a good one.
Toneh
Nice work, was going to reply to this as I've got one of those now in the shed and I had mine apart but nice work man!
I was hoping there would be someway to do it from the control box, as getting it down is a bit of pain.
The reason I finally got round to it, was the screen sits in front of a bay window, and we put the Christmas tree in the bay, and couldn't see the top of the tree!
