Hi All,
I'm just about to have an annexe built with will have a home cinema and I'm looking into getting a new projector all hooked up and need a bit of assistance!
The plan is to get a motorised projector screen 120 inches in size, a I/O panel with 2 hdmi ports, a vga port and RWY input this part itself is a pain to find!
The cables with go via the wall/ceiling, based on the projector calculator this'll be 1.8-1.9m from the wall and I'll be sitting approx 2.5 metres from the screen to view the screen
Tab tensioned screen I'm looking at:
And the shortest possible ceiling mount I can find below (218m from ceiling to top of projector), it's not the most adjustable and I think it's a bit long though based on the limitations of the room being 2.35m in height.
Pic of mount wrapped in spoiler tag as it's a huge picture
Does anyone see a potential problem with the above, the viewing distance or can advise any better mounts so I can have the projector closer to the top of the ceiling with some height adjustments on it that isn't on a huge extending arm.
