Hi all,
last time I had my projector mounted upside down on a shelf I had a cheap £10 ebay mount which did the job but it was a nightmare to get it completely right and would sometimes move and wobble.
This time I want to spend a bit more and get a good one which once set in place, will not move, and is easy to adjust and fine tune for the initial setup.
Any recommendations?
Thank you.
Jake
Thank you.
Jake
