Projector with only 2.8 meters?
4 Nov 2011
Im a complete noob when it comes to projectors but seeing people game on huge screens on youtube makes me REALLY want to get one, The thing is i have a very narrow space 2.8 meters wall to wall, Is there any 1080p projectors that work well in small spaces like this that don't cost the earth?
There's shed loads of pjs that will work fine at that distance at pretty much any budget. I'd go for about 100" at 2.8 meters. What is the budget and, more importantly, can you turn the room into a bat cave?!
Shed loads that do that..? Pls post these as I found there weren't many at all. I have a relatively short throw Epson TW-3200 and that throws just under 100" at just over 3 metres.
I may have been hasty suggesting 100", but At 9' there's loads of pjs that can throw a decent sized image. I think all the JVCs can do 92" with that throw.
You need to become familiar with the term "Throw Ratio" because this will help you short list the projectors that tick your particular box.
Throw ratio is the relationship between throw distance and some facet of the screen dimensions; width, height or diagonal.
Screen dimensions are often quoted as diagonal and in inches, and sometimes nominal sizes too. So a 110" screen might actually measure 108" corner to corner. So it's worth checking the exact measurements and also becoming familiar with converting diagonal to equivalent width and then from inches to centimetres.
For 16:9 screens, width = diagonal ÷ (divide by) 18.35, then x (multiply by) 16
e.g 100" diagonal ÷ 18.35 is 5.45"
5.45" x 16 = 87.19"
Convert inches to cms, inch x 2.54 = cm
e.g. 87.19 x 2.54 = 221.47cm
Once you know the screen base line width and the throw distance from screen to projector lens, you can then work out the throw ratio required to fill the screen from that distance.
Throw distance ÷ Screen width = Throw ratio
e.g. 300cm ÷ 221.47 = 1.35
So, based on screen width, you need a projector with a throw ratio of at most 1.35
The same calculation is possible based on screen diagonal (100" = 254cm. So 300 ÷ 254 = 1.18 throw ratio), you just have to check the manufacturer's web site to make sure whether they're using width (the most common used) or diagonal.
The Benq W1070 has a zoom lens, so there are two throw ratios. One is for when the zoom lens is at the wide angle end (shortest throw) of the adjustment range. The other is for the telephoto end of the range where the throw is the longest. The throw ratio is 1.15~1.5:1 based on screen width.
You can do a simple sum to work out the throw distance. In your case it would be screen width (221.47) x throw ratio (1.15) = 255cm. So you know that this Benq will fit the space and give you the screen diagonal of 100".
The Benq is 1080p native and sells for around £500-£600
Have a look here: http://www.projectorcentral.com/BenQ-W1070-projection-calculator.htm and dump in your measurements
Having read loads of reviews lately and the price the Benq W1070 is going for it's a great bargain.
@ 2.8m throw you can get a diagonal screen size of between 84-110" also take into account mounting position and the depth of the projector too when calculating your throw distance as it may end up shorter than you think.
You can also use the calculator on the benq site: http://www.benq.com/microsite/projector/throwratiocalculator/
Also don't forget that you need to factor in the space behind the lens; i.e. the length of the projector to the wall, allowing for the cables and most importantly enough space for the air to circulate :)
And don't be tempted to buy an ultra-short throw unless your screen surface is perfectly flat and you feel able to align the projector perfectly. The smaller the zoom on your lens the less forgiving it is of geometry problems.
