Hi All,
I have a few issues with the above server, firstly since purchasing the server it has been gaining time, in a month it will clock up +10 mins over the actual time. Because we are using one of these as a domain controller the problem is noticeable.
So today I called HP about this who advised that an updated bios should do the trick, reluctantly I agreed and ran the update, now I have a far worse issues. The fans on the server are stuck at 100% and can be heard all around the building.
I called HP who have been, up until now, about as much help as a chocolate tea pot. Does anybody out there have one of these, has anybody experienced these issues, and more importantly does anybody have a fix.
I have tried rolling back to the original bios and have tried every bios right up to the most recent without any success. I have also tried adjusting the fans with command line using the following:
ipmitool.exe -I ms bmc reset warm
This seems to work with some of our other servers and tends to bring the fans down to 3200ish rpm rather than around 8k+ that these sound like they are sitting on at the moment.
OS is server 2008 x64 with Hyper-V any help would be much appreciated.
Cheers guys.
Cheers guys.
