- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
Upgrade your GPU cooler with the monster MK-13 from Prolimatech. With stocks arriving tomorrow, £39.99 inc VAT is a steal!
Prolimatech MK-13 Graphics Card Cooler @ £39.98 inc VAT
Prolimatech first ever VGA cooler is here, in the name of the MK-13. After claiming the top spot for CPU cooling with the Megahalem, Prolimatech have their eyes set on the throne of VGA cooling.
In the lab tests, equipped with two 120mm fans, the MK-13 proved to be better than today's leading VGA coolers. Best of all is the compatibility list will never become outdated with the Omni-Mount Retention System. The mounting system works by having interchangable parts. As new VGA cards are released Prolimatech will design and release new fittings. There will be no need to buy a new VGA cocoler ever again once you have purchased the MK-13
- Heatsink Dimension: 205 x 99 x 43.5mm
- Materials: Copper Heatpipes and base, Nickle plated heatpips and base, Aluminium fins.
- Six High Quality Copper Heat Pipes
- Up to four fans can be fitted
- Fan Compatibility: 120 x 120 x 25mm
- Suggested Fan Speed: 800 - 2500RPM
- Includes Omni-Mount bracket, Omni Mount Backplate, Fan Secure Holder, Fan Secure Backplate, Fan RAM heatsinks x26, Thermal Compound, Zip Ties, ATI 5800 VRM Heatsinks, and all screws.
ATI
HD-3850 Series
HD-3870 Series
HD-3870 X2 Series
HD-4650 Series
HD-4670 Series
HD-4770 Series
HD-4800 Series
HD-5850 Series
HD-5870 Series
HD-6950 Series
HD-6970 Series
NVIDIA
All 8800 Series
9400 GT
9500 GT
9600 GSO
9600 GT
All 9800 Series
GTS 250
GTX 260
GTX 275
GTX 280
GTX 285
GTX 460
GTX 470
GTX 570
GTX 580
Only £39.98 inc VAT.
ORDER NOW
ATI
HD-3850 Series
HD-3870 Series
HD-3870 X2 Series
HD-4650 Series
HD-4670 Series
HD-4770 Series
HD-4800 Series
HD-5850 Series
HD-5870 Series
HD-6950 Series
HD-6970 Series
NVIDIA
All 8800 Series
9400 GT
9500 GT
9600 GSO
9600 GT
All 9800 Series
GTS 250
GTX 260
GTX 275
GTX 280
GTX 285
GTX 460
GTX 470
GTX 570
GTX 580
ORDER NOW
