- 9 May 2009
hi all
I just bought a Prolimatech Megahalem to install all seems stright forward but just wanted to ask a question about the last two screws that you use to lock the heatsink into place.
the 2 scews how tight do you tighten them i mean do you keep on going untill the screw stops and have it very tight or do you just nip the screw jsut before it stops.
its just i dont know how tight to screw these in as i dont want to over tighten them so that it snaps the screws or the board ?
can anyone help me on this or any tips
