Prolimatech Megahalems
Man of Honour
4 Jul 2008
Hi folks
Just a few questions about the following cooler, hopefully someone has experience with it and can help me out :)
http://www.overclockers.co.uk/showproduct.php?prodid=HS-005-PL
Basically, just a few things.
1, I'm presuming it doesnt come with any fans, but how many fan clips does it come with? Enough for 1 fan only, or two?
2, Putting it plainly, is it worth the money nowadays?
3, I would be planning to put two fans on it, both into the CPU fan header. Is there a cable OcUK currently sell that would allow me to do this?
Thanks a lot :)
i got this cooler with my bundle andit keeps the cpu @ 20c idle i would say get one cos they are really good. i have to sharkoon 2000rpms on mine and they are class...
pair means 2x1 i think
and the pwm fan splitter allows you to connect more than 1 cpu fan to a single fan header whilst still allowing for pwm control ;)
I only see one connector labeled as CPU fan. Are you sure it can do 2? I have one Akasa Viper already, and would want to get a second. They're four pin fans.
Thanks:)!
It can do 3 PWM fans. The power is provided by the Molex. The PWM is provided by the Connect to Motherboard connector.
So where it's labeled "Case Fan", it's able to take a 4 pin?
Thanks for the help guys =)
Oh and I forgot to ask in the OP - Does this cooler usually overhang RAM slots? I've read it's pretty chunky. Would it be a problem for RAM with high profile HS?
It can on some boards, my meg over hangs 1 slot .
