- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Please find our full range of Prolimatech
Prolimatech Armageddon CPU Cooler (Socket LGA1156/LGA1366) @ £49.99 inc VAT
Megahalems was Prolimatech’s first ever CPU heatsink and it quickly became the one to beat and paved the road for all others to follow. Months have passed and competition has once again heated up. One noticible thing is that size has become larger and larger in these heatsinks. This may not be practical as clearance becomes an issue.
With Armageddon, strap on a 14cm fan and let Prolimatech show you that power can overcome size.
- Socket Compatiblity: LGA1156 / LGA1366
- Slim yet powerful for space saving
- Dual or single fan setup
- Six high quality, high performace heatpipes
- Heatpipes: 6 x 6mm pipes
- Suggested Fans: 140 x 140 x 25mm
- Usable Fans: 140 x 140 x 25mm or 120 x 120 x 25mm
- Heatsink Dimensions without fan: 144 x 50 x 160.3mm (L x W x H)
- Includes top quality Prolimatech Heatpaste
Only £49.99 inc VAT.
ORDER NOW
Prolimatech Armageddon 120mm Fan Clips @ £1.99 inc VAT
As standartd to the Armageddon Prolimatech CPU coolers are mounted with 140mm fan. The heatsink has the facitily to be equipped with 120mm fans also. This may for example be useful if you already have high-quality 120mm fans which you want to make use of.
These fan mounting clips allow 120mm fans to be fitted securely to your Armageddon heatsink.
- Fan compatibility: 2x 120 mm
- Cooler Compatibility: Prolimatech Armageddon
Only £1.99 inc VAT.
ORDER NOW
Prolimatech Genesis Mega Performing CPU Cooler (Socket LGA775/1366/1155/1156/AMD AM2/ AM2+/AM3) @ £59.99 inc VAT
Tower CPU heatsinks have been mainstream for the past few years. While power end users may consider them to be pinnacle when it comes to performance, there are others who would prefer down draft low profile heatsinks for their versatile ability to cool not just the CPU but also its surrounding components such as RAM, MOSFET, and Northbridge chipset heatsink. Genesis combines the best of both worlds with top-notch engineering design and superior built quality and performance that are surpassed by none. Either 120mm or 140mm can be installed on the Genesis for a maximum installation of 3 fans of your choice! If you are looking to overclock your CPU to the max while keeping your system stable, we highly recommend the ultimate CPU heatsink, Genesis. The New Era of Super Cooler has arrived.
- High clearance for better motherboard compatibility
- Massive cooling range; cools not only CPU but also MOSFET and RAM
- Cooler surrounding temperature allowing more stable environment for higher overclock
- Takes both 12 and 14cm fans for a maximum installation of 3 fans
- Six high quality heatpipes for effective heat transfer
- Light weight at 800 grams (without fans) in the highend class
- Intel and AMD platform supported. All mounting hardwares are included
- Suggested Fans: 800-1600 RPM
- 6 x 6mm heatpipes
Only £59.99 inc VAT.
ORDER NOW
Prolimatech Genesis "Dual Red Vortex Edition" CPU Cooler (Socket LGA775/1366/1155/1156/AMD AM2/ AM2+/AM3) @ £64.99 inc VAT
- 6 x 6mm heatpipes
Fans
- Dimension: (L)140mm X (W)140mmX (H)25mm
- Bearing Type: Sleeve bearing
- Rated Voltage: 12 VDC
- Operating Voltage Range: 7~13.8 VDC
- Rated Current: 0.2 Max.Amp
- Rated Power: 2.4 Max.Watt
- Rated Speed: 1000±100RPM
- Airflow: 87 Max.CFM
- Noise Level: 18.1 dBA
- Net Weight: 162 Gram
- Connector: Terminal Connector(3-pin plus 4-pin molex)
Only £64.99 inc VAT.
ORDER NOW
Prolimatech Genesis Fan Clips - 120 & 140 mm @ £1.99 inc VAT
The Genesis Prolimatech is one of the most powerful CPU coolers in its range. This fan comes with four terminals, which include the installation of two 140 or 120mm fans. This accessory allows the mounting of a further 140mm or 120mm on the Genesis in order to increase the cooling capacity even further.
- Fan compatibility: 140 x 140 x 25mm / 120 x 120 x 25mm
- Cooler Compatibility: Prolimatech Genesis
Only £1.99 inc VAT.
ORDER NOW
Prolimatech Lynx CPU-Cooler (Socket Intel Socket LGA 1156/1155/AMD Socket AM2/2+/3/3+ ) @ £24.98 inc VAT
Prolimatech's first cpu cooler for entry level computer system, the Lynx! It has three high quality nickel plated heatpipes with aluminum fins for effective heat transfer. The compact design provides high compatibility, perfect for small chassis.
It supports Intel socket LGA 1155/1156 and AMD AM2/AM2+/AM3/AM3+.One 120x120x25mm PWM fan (800~1600 rpm) is included and it is also possible for adding fan to maximize cooling performance!
- Three high quality nickel plated heatpipes for effective heat
- Equipped with one 120x120x25mm PWM fan (800~1600 rpm).
- Option for adding 2nd fan to maximize cooling performance.
- Flexible mounting kits for Intel socket LGA 1155/1156 and AMD AM2/AM2+/AM3
- Compact tower cooler, perfect for small chassis.
- Heatsink Dimension: (L)118mm X (W)70mm X (H)159.5mm
- Heatsink Weight: 400 g(heatsink body only)
- Included Fan: 120 x 120 x 25 mm Black PWM fan
- CPU Platform: Intel Socket LGA 1156/1155 , AMD Socket AM2/2+/3/3+
Only £24.98 inc VAT.
ORDER NOW
Prolimatech Megahalems Rev C CPU Cooler (Socket 775/1155/1156/1366/AMD AM2/AM3/AM3+) @ £54.98 inc VAT
The tower type coolers have been the mainstream in the CPU cooling market for quite some time now, but upon closer inspection you start to notice that designs and engineering can only go so far as they are slowly come to a bottleneck. After a while they all start to look the same with performance not worth popping the champaign. This is where Prolimatech comes in. We are here to challenge all possible odds and stray away from the norm. With that focus in mind comes the new Megahalems, tower CPU cooler. Never before seen are the new lows in temperature produced by an intelligent design of low air flow resistance with unmatched performance to boost; perfect for the true overclockers in all of us.
- Heatsink Dimension (L)130mm X (W)74mmX (H)158.7mm
- Heatsink Weight 790g
- Heatpipe Ø 6mm X 6pcs
- Suggest Fan 120mm X 120mm X25mm
- Suggest Fan Speed 800~1200rpm
- Suggest Noise Level (dBA) Below 26dBA
- Direction of heatsink faces the rear exhaust system fan
Only £54.98 inc VAT.
ORDER NOW
Prolimatech Megahalems AMD Retention Kit (Socket AM2/AM2+/AM3) @ £9.98 inc VAT
Looking to make the switch to AMD AM2/AM2+/AM3? Installation has never been easier with our AM2 Retention Mount Adapter Kit; you can literally install it in 5 minutes or less! What’s more is that you get to choose any direction for your Prolimatech heatsink to face; parallel or perpendicular to your rear exhaust system fan. Each AM2 Retention Mount Adapter Kit is designed and built to provide sufficient amount of pressure for a secure and firm grip on your CPU heatsink. With Prolimatech, you can count on the high-quality built and sound stability from any of our products and major accessory parts to last as long as or longer than your computer’s life span.
Only £9.98 inc VAT.
ORDER NOW
Prolimatech Panther CPU Cooler (Socket LGA1155/1156/AM2/AM2+/AM3) @ £37.99 inc VAT
Prolimatech has taken its inspiration for this new cooler from the Armageddon, which results in the same excellent performance at a brand new price point. Both feature the same heatpipe shape, with the only difference being the number of such element as the Panther offers four 6 mm pipes.
In terms of construction, the cooler makes no compromises and offers the same level of quality as one has come to expect from Prolimatech. High quality Nickel plating has been applied to the entire cooler which does not only protect the unit but also results in a great look and feel. On top of that, the crossed fins increase the robustness of the Panther cooler.
The sophistication of this construction also shows in the shape of the heatpipes. These end in a row next to each other, so that each of them has unrestricted access to the fresh airflow of the included fan. This maximizes the efficiency of the Panther CPU cooler, while keeping the dimensions to a minimum.
The 120 mm fan with PWM connector can be controlled automatically by every modern mainboard in the market to keep the noise to a bare minimum. This cooling unit also features transparent red blades along with red LEDs. Prolimatech has also included a second set of clips, allowing the installation of another such fan for a push/pull configuration, further raising the performance bar on this cooler. Also part of the package is the award winning PK-1 thermal past and the very sturdy mounting kit with backplate for Socket 1155, 1156, AM2, AM2+ and AM3.
- Dimensions (with fan): 130 x 158 x 73 mm
- Heatpipes: 4x Ø 6 mm
- Fan: 120 mm (Red LED)
- Fan Noise: (29,1 dB(A)
- Fan RPM: 1.600 U/min +-10%, max.
Only £37.99 inc VAT.
ORDER NOW
Prolimatech Samuel 17 CPU Cooler @ £37.99 inc VAT
In the Old Testament of 1 Samuel, Chapter 17 tells a story of an ordinary man named David whom nobody believed in. That did not matter to him because David had something to put his trust and faith in. From that he would get his strength to battle the nine-foot-tall giant, Goliath. In the end, against all odds, David did prove that size does not matter when he defeated Goliath.
Prolimatech Samuel 17 has the essence of David. It is compact in size but don’t let that fool you as it packs a deadly arsenal in a never ending battle against heat. When equipped with a 120mm, Samuel 17 will not only cool your CPU efficiently but also the PC components around it, keeping your computer running smooth and stable.
- Unique 6-high quality-heatpipe-down-draft style CPU heatsink.
- Super compact heatpiped CPU cooler at 45mm tall, perfect for HTPC system.
- No installation interference issue.
- Supports low RPM 120mm fans on a relatively smaller heatsink body.
- Decreases temperature on surrounding PC components.
- Supports ATX, microATX and mini-ITX form factors.
- Supports Intel LGA775/1156/1366 and AMD AM2/AM2+/AM3/AM3+.
- Suggested Fan: 120mm X 25mm or 120mm X 12mm
- Suggest Fan Speed: 1000~2000rpm
- Suggest Noise Level (dBA): Below 26dBA
- CPU Platform: Intel Socket LGA 775/1366/1156/1155 and AMD AM2/AM2+/AM3/AM3+.
- Heatsink Dimension: (L)121.2mm X (W)120mmX (H)45mm
- Heatsink Weight: 410 g
- Heatpipe: Ø 6mm X 6pcs
ORDER NOW
Prolimatech Super Mega CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366) @ £59.99 inc VAT
Prolimatech's latest new high-end CPU air-cooler, the Super Mega is here. This cooler is based on the popular Megahalems dual fin-block tower design, except for a dash of copper fins sandwiched between aluminum fins. Measuring (L)130mm X (W)74mmX (H)158.7 mm, and weighing in at 945.3 g, the Super Mega uses six 6 mm thick nickel-plated copper heat pipes to convey heat to two independent aluminum-copper fin blocks, which make up the shape of a conventional tower cooler, but increase turbulence. The cooler can hold 120 mm and 140 mm fans on either sides, and supports all latest CPU sockets, including LGA1366, LGA1156, and LGA775.
- Copper and Aluminum Hybrid for best heat collection and dissipation ratio.
- Copper fins are strategically positioned for better heat dissipation.
- Top fin made of scratch-resistant stainless steel to preserve shine.
- Minimal air resistance between fins allowing best balance between noise and performance for fans in the range of 800-1200RPM. For all out performance, fan RPM at 1600 or above is recommended.
- Vertically adjustable 120/140 mm universal fan clips redesigned for better installation compatibility.
- The Black screws are included to provide extra pressure for better contact with CPU and heatsink.
- Heatsink Dimension: (L)130mm X (W)74mmX (H)158.7mm
- Heatsink Weight: 945.3g
- Suggest Fan: 120mm X 25mm ,140mm X25mm
- Suggest Fan Speed: 1000~1200rpm
- CPU Platform: Intel Socket LGA 775/1155/1156/1366
ORDER NOW
Prolimatech LGA2011 CPU Cooler Socket Kit @ £0.98 inc VAT
Upgrade all of your Prolimatech CPU coolers for the latest LGA2011 platform.
- Pack of 4 screws
- Easy upgrade
- Easy install
Only £0.98 inc VAT.
ORDER NOW
Prolimatech PK-1 Nano Thermal Compound (30g) @ £19.99 inc VAT
The Prolimatech PK-1 Nano Aluminium Thermal Compound is thermal compound that is entirely environmentally safe and recyclable. Even with that being said it is at the head of the pack as far as performance, and is very easy to apply.
- Excellent long-term stability
- Non-electronically conductive
- Non-corrosive
- Easy to apply and less to use
- No "burn-in" time required
- Low dry-out
Only £19.99 inc VAT.
ORDER NOW
ORDER NOW
Only £1.99 inc VAT.
ORDER NOW
- 6 x 6mm heatpipes
ORDER NOW
- 6 x 6mm heatpipes
Fans
ORDER NOW
Only £1.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
Only £9.98 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
- Pack of 4 screws
- Easy upgrade
- Easy install
Only £0.98 inc VAT.
ORDER NOW
- Non-corrosive
- Low dry-out
ORDER NOW
