Proper way to check Automatic Gearbox Oil Level?
11 Jun 2004
Middlesex, London
Hi all,
Please can someone tell me what is the proper way to check the level of Automatic Gearbox oil..?
Thanks
should be in the manual. On my car it tells me to drive for 20mins, stop and then slowly push the selector through each gear waiting 5secs in each. After this check the dip stick.
There is a cold mark on there as well but the manual says a warm reading is far more accurate.
You have to check it with the engine idling as well. Otherwise the fluid will get caught up in the torque converter.
