Properly Seasoning Carbon Steel Frying Pans
25 Nov 2020
After tiring of repeatedly buying non-stick (ceramic/stone) pans every few years, my wife and I have bought a couple of De Buyer pans based on recommendations on the OCUK forums.
We have followed various YouTube instructions for seasoning and they only really half-work for us..
In such videos you'll see pans that have such great seasoning that they look coated. Ours, on the other hand, have patchy areas that look great, then areas that are almost clean steel. Every time we get close we notice burnt on food so use the chainmail scrubber and that sets it back a little.
I'm under the impression that the whole purpose of the seasoning is to have a patina that feels smooth (ie zero traces of burnt on food) but looks consistently dark throughout.
The oils we have are: avocado, rapeseed, flaxseed, sesame. We're happy to buy others if what we have is no good.
Throwing it out there - How do you season your pans effectively?
photos encouraged.
Sesame works well for me.
You need to be careful about what you cook in it, acidic things will strip the seasoning, including tomatoes.
Every now and then if the seasoning is going, I chuck some vinegar in the pan and scrub it with wire wool until it's absolutely clean and blemish free, then re-season it.
