Hi All.
I am considering an upgrade in the near future. I am unsure as to how much my budget will be and how far away it will be. 2-6 months, I am guessing depending on how much cash I will be able to save up vs how much I will end up spending.
My current spec is:
Intel Core i5 2500 (stock cooler)
Asus P8H67 R3 H67
Corsair 8GB XMS3 1333Mhz
Seagate 1TB Barracuda
PowerColor HD 6870
OCZ Fatal1ty Series 550W
Bitfenix Merc Alpha
Windows 7 64 bit
LG IPS235V
Saitec Cyborg V.3 Mouse
Keyboard, some HP thing
Logitech 2.1 Speaker System
Over all it does what I need and does not feel to sluggish. I mostly use it to do some programming and some gaming.
I was mainly thinking of replacing my case with either a Corsair 650D or a Vengeance C70. Not yet decided which would be better or if there is another case I should be looking at. Sticking with air cooling and I like plain looking cases.
I think my PSU should keep just fine, though I was thinking I'll get some PSU extender cables though for better cable management, the cables on my current PSU feel a bit short reaching up to the CPU.
I certainly need a new keyboard and a decent mouse mat or gaming surface or what ever its called. I currently use a 50p mouse mat from Ikea
Even though I am not overclocking I think an aftermarket cooler should not go amiss.
I think my graphics card should hold for the moment and same goes for my CPU.
I know an SSD would make an improvement though I am not sure on if I should get one.
I am understand advice is rather difficult to give with out a clear budget and no clear time frame, but any suggestions and advice would be most welcome.
My current spec is:
Asus P8H67 R3 H67
PowerColor HD 6870
Bitfenix Merc Alpha
Windows 7 64 bit
LG IPS235V
