Protect your precious......
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys.
We have a great new surge protector which covers electical power sockets, LAN Ports and your telecommunication scokets (ie. Modems/Broadband).
Such a quick, low cost solution is much better than the £100s or £1000s it could cost you if you are unprotected from electrcial surges and spikes.
Surge Protected Power Centre with 8 Socket/LAN Port/Telecom/Modem/Broadband Protection - 2 Metre @ £19.99 inc VAT
Fellow gamers and enthusiasts know of the heartache when your precious computer is out of action. So why not do all that you can to prevent outtages due to damaged hardware. Well now for an amazingly low price you can have the peace of mind that you are protected against electricial surges and spikes.
Hundreds of power surges can occur in your home or office everyday. The switching on and off of lights and household appliabces like refridgerators, washin machine and tuimble dryers can cause surges. Most warranties do not cover power surge damage, and these surges and spikes can cause serious damage to your electronic hardware. Even low energy surges and spikes can cause gradual component degradation leading to hardware failure. The manufacturer MasterPlug are that confident in their technology that this MasterPlug product comes with a 'connected equipment warranty'. In the unlikely event that a surge passes through this device and any damage occurs to your hardware, MasterPlug will pay up to £3000 for the replacement equipment*.
- Surge protection for your home office and PC equipment: computers, fax machines, scanners, routers, from damaging surges and spikes.
- 8 Surge protected power sockets with three channel protection & safety thermal cut-out
- Power & surge neon indicators. LAN/Ethernet Surge protection. All necessary leads supplied.
- Telecom/Modem/Broadband connection surge protection with telecom splitter provides protection for two devices from one input.
- £3,000 connected equipment 3 year warranty for peace of mind*.
* Subject to warranty registration online at the time of purchase.
Only £19.99 inc VAT.
ORDER NOW
Nice if all your precious devices are in one place.
Opted for a UPS though mainly because of the file server. Not good for disks to spin down with power shortages.
I know my powerline kit seems uneffected being in my surge protection. My powerline kit states not to use in a surge protection kit.
might vary with kit and age, some of my older powerline equipment did not play nice with surge protectors, I have since moved to regular cabling though so no idea if this issue is still around.
No idea. I don't know if powerline kits get affected by surge protectors.
I remember reading a while ago that surge protectors were meant to affect the speed through the powerline kits.
http://www.dlink.com/us/en/home-solutions/connect/powerline/dhp-301-powerline-hd-network-starter-kit
Connecting this product to a power strip with a surge protector may adversely affect the performance of this product.
TP-Link 200Mbps Wireless-N300 Powerline Extender Kit (cnt link site as its competitor)
Powerline adapters can be used with extension leads (except surge protection ones), and will work across different ring mains so long as they share a common fuse box.
Linksys by Cisco PLTK300
As a word of note to anyone using Powerline products, make sure you do not plug these in through a Surge-Protected socket. They will happily take a regular multi-gang extension plug if need be, as long as there is no surge-protection on it, as it will disrupt the signal and prevent the network from forming.
I think
applies because i have seen some network videos where they test over surge protection and it doesn't appear to degrade performance from the tests they performed. I tried it in surge after being solely wall socket and havent noticed any issues with any aspects since going into the surge protection. Someone needs to try it and see.
I have just checked with our Powerline buyer, RJKONEILL
He has indeed confirmed surge protectors do not affect the speed of powerline adapters.
He uses powerline at home, and uses it on a surge protector.
