I'd like to know what the standard solution to this problem is. Raw copper will be attacked by water. Are the inside of water blocks lacquered/painted/electroplated or just left as bare copper on the basis that it won't corrode very fast?
Nickel plating seems to be the obvious answer, but it's evidently not the only option.
Cheers
Cheers
