Protein suggestion.
4 Apr 2004
Manchester
Looking to order on MyProtein.com a big tub of the protein drink. My question is, which is considered to be the most potent? Which one does everyone else go for? And is there something extra that compliments the protein shake well as an additional supplement.
Thanks.
Id personally just order some whey protein concentrate in a big tub, using
http://www.bulkpowders.co.uk/
as a reference for price match...
Then if i was training i would probably just pair that with some Creatine Ethyl Ester or something as an additional boost :)
im not too clued up compared to some, chances are i might just get laughed at :)
What level are you at? If you're at a level where you will benefit from the difference between 'concentrate' and 'isolate' then get the isolate as this is probably the most 'potent'. I would say the difference between the two is negliable for the casual trainer, though.
I recently took delivery of their 10lb isolate as it was cheap (unflavoured) and have absolutlely no complaints. As Hedge says, use the url of BP for the price match for some deals.
If budget stretches then maybe go for their MP Max range? It's a blend so suitable for other times of day too. Again, I'm a novice so may get laughed at too :p
First order? MP38291 as a referral code for 5% off first order ;)
