Hi,
I've written a help desk in PHP and MySQL for school which I've setup on an internal machine. Now, the help desk is working fine on that machine by using http://localhost but when I try and do it from another machine on the network by typing in http://172.17.100.41 it times out saying Connection timed out - 10061(I think), ISA server (Or something to that effect). Now if I go into internet options and change the LAN settings tab so there is no tick in the use proxy box, it works but then no other websites work. I thought it would be a case of using the 'Bypass proxy server for local addresses' box but it does the same thing
I therefore came to the conclusion that it's a settings on the proxy but don't know where to start. The proxy is running windows 2000 server and clients are on XP Pro
Thanks for any help
Ben
Thanks for any help
Ben
