- 23 May 2006
Hey guys, I have already posted this in the overclock part of the forum, but I did not really get anywhere. Maybe some of the guys that keep an eye on RAM can help me out. In short it seems that I have a choice between 8GB of RAM or I have a 3.2Ghz CPU.
My original post was this.
Hey guys,
I would really appreciate some help with my problem, first i'll give you my specs
P5Q Pro MLB
OCZ Gold Edition 4GB (2x2GB) PC2-6400C5
E6600 CPU 2.4 clocked to 3.2
Now, I decided to buy another 4GB of RAM, the exact same set as above, so I now have 4 sticks of 2GB each. As soon as I start my pc I get no display, the PC is running, but my monitor seems to receive no signal. So, I reset my PC and on power up I was warned that my previous attempt at overclocking had failed, I pressed F1 to reset to default setting and my pc started up fine. I have tried just changing the FSB from 266 to 285 and still just a blank screen.
Now, I have next to no knowledge about overclocking, all I done in the past was just change the FSB up until my PC booted into windows (64 bit vista btw) and then I would stress test it and keep an eye on temps, I found that 3.2 was the point at which I could get into windows and seem to be stable. I have read the guides on this site and used google a fair bit, but I really do not understand what I need to do. I have upped the DRAMM voltage a little, CPU voltage and played with the dividers, but to be honest it's all guess work and I have no real idea what most of the setting options in my boot setup mean.
Thanks for taking the time to read, as I say, any advice would be great. I am hoping its a completely simple and easy thing I am not doing right
Hey guys,
P5Q Pro MLB
