PS2 Access point
29 Jun 2004
I have a PS2 downstairs and would like to use this online but cannot run a cable round the house so could i plug an access point into the back of the ps2 then use it with my wireless router? thanks
ants83 said:
hmm could you tell me how to set this up im a little confused sorry
Well you need to setup the access point using a pc, so that it connects to your router as a client. Once it's setup, you connect it to your ps2 using ethernet and that's it :).
Phnom_Penh said:
Either will do. An access point (with client abilities) is probably a better choice, depending on whether the bridge needs WDS or not.
An access point costs more, and I'm pretty sure it needs to be connected to a pc or router to provide the connection.
Energize said:
An access point costs more, and I'm pretty sure it needs to be connected to a pc or router to provide the connection. He already has a wireless router.
? wtf. No. Something like a SMC smcwebt-g would be fine (their reliability seems fine) and they just connect to the router as a client, and cost £35.
It doesn't if, as phnom_penh suggested, it will work as a wireless client.
As for a bridge/"game adapter" being cheaper:
Netgear WGE111 54Mbps Wireless Game Adapter (NW-094-NG) - Price: £43.95 (£51.64 Including VAT at 17.5%)
Netgear WG602 54Mbps Wireless Access Point (NW-012-NG) - Price: £36.20 (£42.53 Including VAT at 17.5%)
The cheapest being a Belkin at an entire £2 cheaper than that Netgear AP.
That product is titled as being a bridge.
Pffft. It's a wireless access point which can bridge :p.
Going by the experiences I've had with hardware from Netgear, and what i've heard about Belkin, I wouldn't buy either :p
Only thing ants might have to worry about is extra lag due to the wireless, but that's up to him.
So whats the difference between a bridge and an access point?
On every website I've seen so far bridges are described as connecting a wired device to a wireless network and access points as attaching to wired network and giving wireless devices the capability to connect to it, but they state that waps can't recieve their network connection from another wireless device.
I don't know exactly, but at a guess, a bridge can only act as a client, and not as an access point, whereas most access points can at as a client and/or an access point... Ie you can connect wirelessly as a client to an access point, but cant connect to a bridge.
It wasn't a recommendation, I've not totally lost my marbles (yet) :p
"Every website you've seen" are wrong then.
A bridge connects two different networks - one of the networks only having one node isn't relevant.
You could easily connect a switch to the ethernet port on a bridge, and all those devices would connect through the bridge to the wireless network (but wouldn't be aware that the network beyond the bridge had a wireless segment).
The distinction's between an AP that'll work as a wireless client (ergo a bridge) and one that won't (that's in an extreme minority).
