PS2 and HDTV ?
18 Oct 2002
Nottingham
Hello,
Just set up my PS2 on a HDTV whats the best connection to use ?
Just using SCART at the moment.
Is there a better cable to buy ?
Thanks Ben
I think a ps3 component would work with it, but you will not see much improvement unless the game supports progressive scan.
Any idea how much one of them cables is ?
I am jus gonna be playing all 3 metal gear soild games do they support pro scan ?
BEN_UK said:
Hello,
Thanks Ben
Does your HDTV have a HDMI port? If so then thats the best one to go for.
