PS3 3D - help!
20 Nov 2011
I have just bought an Asus VG278H 3D monitor, but can't get it to work in 3D with my PS3.
I know that the monitor is HDMI 1.4 compatible, but my HDMI cable may not be 1.4... is there a special cable I'd need?
No, the PS3 itself isn't even 1.4 so you don't need a special cable.
Do you get any error messages when trying to enable 3D?
I just get the message in PS3 games that I don't have a 3D Compatible display plugged in. I know others have this working with PS3 in 3D though.
Might be a long shot but try resetting your video settings by turning off the ps3, then turn it back on holding the power button for 5 secs. If that doesn't work I'm stuck.
I'd say head to the video settings. I've had my PS3 a while but only had a 3DTV for a month. The first time I used to the PS3 on it, the startup was interupted by a message saying something along the lines of "3DTV detected. do you want to enable 3D?" and then "choose your screen size to get the best 3D performance"
