PS3 audio help
13 Oct 2006
Surrey
Right I'm planning to buy a PS3 in the near future. My main issue however is with the audio. I will connect it from the HDMI port to my monitors HDMI so thats the picture sorted.
I have an old surround sound system which has 6 co-ax inputs, 2 for front speakers, 2 for rear and 2 for the woofer. Is there any way I can connect this to the PS3?
Cheers
Cheers
I guess it doesnt have an optical input then? Anyway you only other way is to use the A/V cable that comes with the PS and connect that to your amp front speakers using the normal composite leads (Im guessing thats what you mean), you then select it as the Audio output and its sorted, but only in stereo rather than 5.1 for optical or 7.1 from HDMI,
May have to fork out for an optical or hdmi amp then. :( As mentioned above you will only be able to get stereo sound using composite or component via the av-out port.
Co-ax is copper or something isnt it?
I'm thinking that I may have to go for a more expensive system, like the z-5500
Is your PS3 in you bedroom? I was looking for a 5.1 optical system a while back and was looking at the logitech Z-5500, but after looking i got a yamaha amp and speaker package (cant remember exactly) it was about the £200 mark inc delivery, and had 2xoptical 1x co ax digital inputs and 5.1 speakers. Not the best sound in the world but better than my old logitech ones i had.
Also have you considered using 5.1 headphones?
I thought co-ax was the same as optical?
...I have an old surround sound system which has 6 co-ax inputs, 2 for front speakers, 2 for rear and 2 for the woofer...
The inputs the OP mentioned originally are presumably for phono leads, and would normally be used if you are using a separate decoder. Often there's one for centre and one for sub...
thecremeegg, if you're happy with stereo for the time being, you could probably still get the bass from your sub, similar to how subs work in a Dolby Pro-Logic system.
To guide you more clearly, you'd have to post the specifics of your system (all the outputs of you amp, whether your sub has cut-off frequency control, etc...)
Its a pretty basic amp/sub combined. Does its job for me so obvously I'd like to keep it but it looks like I wont be able to. As I described before, they are the only inputs on the rear :)
...As I described before, they are the only inputs on the rear :)
well, I was asking about outputs, not inputs... Having said that, do you not have standard RCA inputs, such as those label tape/tuner/video, etc?
Point being that you can connect the PS3 to your amp with the basic RCA phone leads (red/white cables) but still get adequate sound.
For example, on my sub (it's about 10 yrs old I guess) there's speaker cable connections and a standard single RCA that connects to the 'Sub Out' from the amp so even on a stereo/pr-logic setup, either connection will give you plenty of bass. In fact, chances are you will get too much bass that way, hence the need to tweak the cut-off control to suit your taste.
There should also be bass settings on the amp that will affect the sound output...
