PS3 backwards compatability
Vengance said:
Been playing ffvii on my ps3, no problems so far. Wonder why its not on the list :confused:
Whats the quality like on this, now I have a ps3 im thinking of picking up ff7 and ff10, also what tv and cable are you using. Is the quality same, better or worse than the ps1/ps2.
Thanks mate ;)
its obviously worse (if you have an lcd). its a low res output blown up with no scaling to fit hd resolutions.
hopefully they'll get some advanced processing options going soon, that should clear the output up a bit.
oh yeah. dont expect to be blown away by the graphics and you wont be disappointed. everythign ive'd tried works and it's all perfectly playable:)
Anyone played Pro Evo 6 on the PS3?
Want to buy this for it but want it to be OK on my HD TV etc. I take it I can play it online etc?
Agr3sive said:
Hopefully it shouldnt be too bad then as I only have a 26inch LCD, I can imagine it would be worse on a 40inch+ panel.
i'm playing on a 42" screen, so yeah, you shouldnt have any trouble.
