Jihad said:Anyone got any they can reccomend?
£30 and below if possible, not sure what to look for in the headsets never had to get one before.
rp2000 said:I have this one: motorola h350
Jihad said:Just found out my Dads got a Jabra BT250V which he doesn't use much.
Only problem is I found on AVForums that model has this issue;
"works but re-registration/pairing issue"
Anyone able to elaborate?
Oh right doesn't sound like a big deal then.rp2000 said:Some of the headsets need to re-paired every time the console is rebooted. I think that is what it is referring to.
rp2000
I just got myself one of these off the bay. Problem is I dont have instructions - how do you get it into Pairing mode?spudstudios said:I got a motorola hs850. Very nice. Auto on when you open the boom.. Off when you dont. sorted. ( Cheap off auction site)
like most others, matches the ps3 a bit also looks great and only 14 grams its so light, anyhow my spare brand new jabra bt125 going up on members market later tonight or tommorow.
