PS3 connection issues.
19 Sep 2007
I have just installed Vista 32 bit and for some reason my PS3 has now very bad connection issues, to the point that I get a maximum of 22% at any one time. But my 360 connection is fine.
Before on my XP the conenction with my PS3 was always buggy, but had connections of about 50-60%...
Anyone know the reason for this at all?
Am using the same router/modem combination as used with my XP setup.
Your router/modem is it wireless ? if so then what OS is on your PC will have no bearing on the connection between the router and your PS3
