PS3 disable controller start
18 Oct 2002
Amsterdam,The Netherlands
Recently I have been using a PS3 controller on the PC to play GRID but whenever I shut down the PC the controller makes my PS3 turn on (2 floors down.!!!)
Is there a way to stop the PS3 turning on with a controller?
Do you need any drivers / software to get the PS3 controller working with a PC?
What about bluetooth, is there a way to pair it?
You just connect the controller up and there's an exe you can run to make your PC recognize it, usb only.
Does it handle pressure sensitive on the PC? I didnt think of the USB connectivity, could be handy :)
also, you know when you press the PS button and the light starts flashing as it looks for a PS3, how do you then tell it to stop and switch off? Ive had this happen a few times when im on my way to a friend's house, no PS3 in range on the train :p, but cant tell the controller to switch off
