I'm running this 22" monitor http://www.overclockers.co.uk/showproduct.php?prodid=MO-006-BE&groupid=703&catid=17&subcat=949
With an HD Fury cable going from the PS3 to the monitor and if I run in 720p the image I get on the monitor looks like it is split into vertical sections via faint lines, If I sit a few feet away from it they are less visible but still noticeable.
If I run it in 1080p I get no such lines but as the monitor doesn't support it, it is cutting off some horizontal and vertical pixels which is equally as annoying, does anyone know if there is a way to fix this without buying a new monitor?
Also the lines are static i.e. they don't move down the screen.
It looks a little like this.
