PS3 does not show up on LCD
27 Dec 2006
Northampton
Hello
I've got a bit of a strange problem when hooking up the PS3 and Sony kdl40v2000. This is all connected via HDMI cable.
When loading up the PS3 - no signal comes up. And when randomly pushing the controler i manage to load up a demo and there was a signal showing:confused:
Once i went back into the menu it disappeared. It can't be either the HDMI cable or connection slot because i tested the 360 and works fine.
Are there supposed to be TVs that are not compatiable with lcds?
Ok, switch off your PS3, then when you switch it on hold the power button for 3 seconds, you should then hear a beep. This beep signifies that it has reset itself to the default video options and hopefully a picture will appear. You can then set what resolution options you want in the options menu.
This issue typically occurs when the PS3 is set to a resolution your tele doesn't like, resetting it 99% of the time fixes the issue.
Ding ding ding - winn0r!
thanks for this. The PS3 was orignally connected to this PC monitor. I'll do the reset when i plug it back.
