I am on a virgin media 20meg download speed.
When downloading ps3 demos its painfully slow.
More than an hour and a half for an 850 meg demo.
On my 360 the same size demo takes about half an hour.
I know virgin throttle after downloading a certain amount at peak times?
Yep 4pm-1am, but I tested both and my PC was pulling in about 2.3mb/s from my newsgroup and my PS3 took 5 hours to download Tekken 5.
Obviously I turned off the newsgroup download first.![]()
Are you guys making sure you have your ports forwarded properly for PSN?
Stuff I download from PSN absolutely flys down the line.
Hmmm well when my internet is shaped my newsgroup speed is also reduced so I don't think it's anything to do with the protocol, I've never had speed issues with NTL/Virgin and have been perfect with them for like 3 years now. Yeah I had every port forwarded for the PSN and the 'good' NAT type and everything set up, wired/wireless gave same slow speeds.I take it you are with Virgin Media as well (guessing by your 2.3mbps download). Seems like the common link between you and the OPer is the ISP you have.
A better test would be to try something like a service pack or large file download over http. To compare the ps3 download with the newsgroups is silly as they both use different protocols, and often shaping throttling is done by protocol.
tbh it would not surprise me if it was a problem at Virgin Medias end as from everything I have read, they wee having capacity speed issues even before they added the throttling. They are falling into the "greedy" ISP trap of rebranding, advertising like crazy, but not upgrading back end capacity.
I think you can download SP2 from this link to test, I always use this to test. 90% of the time you will be maxed out at your end. I guess on a 20mb connection that should be around 2.4mbs
http://www.microsoft.com/downloads/...0-73cf11fdcdf8/WindowsXP-KB835935-SP2-ENU.exe
rp200
Tekken 5 wasn't the only slow download though, everything was slow at any time, in unshaped hours too, maybe it was a bad network adapter maybe not, will find out soon anyhow.
Nah I had mine the same month the shaping and what not was introduced, I tested it after and before shaping hours and it was the same problem, I tested Multiplayer FTP and was pulling like 1.8mb/s off that then I turned it off went on my PS3 and it took about 20 mins for a 40mb trailer.Yours is harder to judge, as I think you had a ps3 before the virgin media throttling started.
I suppose you will be able to test better when you get the new ps3. Its just to me the only people who are mentioning slow speed are on Virgin, and I know from many people that they have not been perfect for downloading large files in the past, also any ISP that has to throttle, instead of buy more capacity, tend to always be doing shifty things in the background.
It is just as likely it is not your ISP and some other issue, but you can see my point based on the examples in this thread?
rp200
I see your point but I can't really think it's the ISP when everything else is working fine, oh well. If I get the same issue again I'm gonna get to the bottom of it.
Also it couldn't have been my router either because I used a direct connection to my modem to test it just remembered that.
Oh well will wait and see what happens.![]()
The PSN is free so I think they will use slower severs and every 360 demo has come down in a hours, the only one that took ages was Bioshock
Can't recall any Live downtime? only when it's been scheduled
