PS3 DVI?
12 May 2005
I was thinking of when I get a PS3, my 2 20" monitors both have DVI and VGA ports. Is there a way to plug the PS3 in to the DVI ports, since HDMI is basically DVI but with audio?
It will all depend, you can get an HDMI to DVI converter/dongle but it will only work if your monitor can accept HDCP iirc.
Ok thanks to both of you :)
Last thing, what connection options do I have? I only have the left/right white audio leads (the ones like a composite cable) and on my PC surround sound I have a headphone jack like connection...
