PS3 Fat32 USB Limitations
25 Oct 2009
Caerphilly
Can find much at all online about this.
Is there anyway around the 4gig file size on Fat32 partitions?
I want to play some HD films on the PS3 but all the files are over 4gb :(
I'm sure you can Media Stream them from a Computer to the PS3. I used to do this with Music and Videos all the time when I had a PS3.
Split the files, or alternatively you can stream the files from your PC to Ps3.
If you need to split them then use MKVToolNix.
